7-Bedrock
Number as the first alphabet in field definition of a Data Shape
Is it possible to give a number as the first alphabet in field definition of a Data Shape ?
If no , is there any thingworx configuration modification that can be done to achieve this.
Sadagopan Ponmani
slangleyAnswer
Support
Hi @psskps.
We are not aware of any way to change this behavior.
You can submit this as a request on the ThingWorx Ideas forum which will allow others to vote for it.
--Sharon
Hello @psskps,
When I am creating an entry in the Field Definitions it doesn't allow the name to begin with a number. You can use numbers within or at the end of the name. Have you tried starting first with a letter followed by a number ?
psskps7-BedrockAuthor
7-Bedrock
Hi @Ciprian-Traian ,
Yes i have tried with alphabets first , followed by numbers. But i have a requirement where i need the numbers to be the first letter of the datashape.
Anyway, Thank you for the response.
Support
Hi @psskps.
If the previous response helped you to find a solution, please mark it as the Accepted Solution for the benefit of others with the same question.
--Sharon
slangleyCommunity ManagerAnswer
Support
Hi @psskps.
--Sharon
