Hi @VC_10938534
Ordinary Text Box can hold the String, and that allows all the symbols to be entered, and there’s no way to limit the input.
You could try to use the Masked Textbox widget, it’s also an embedded widget in the composer, and it limits the length and the input can only be Number and English Characters.
Here’s how to use the widget, https://support.ptc.com/appserver/cs/view/solution.jsp?n=CS249516&posno=1&q=masked%20textbox... , please reply to ensure it’s what you want.
Surya
11-Garnet
Hi Surya,
I unfortunately don't have the masked textbox widget would there be another widget that I could possibly be using instead?
Hi, @VC_10938534  You can use a custom widget according to your use case.
