OData Connector Method POST Error
Hello everyone,
I am trying to connect to SAP using the OData Connector. We have been able to successfully perform all the GET calls but we haven’t been able to do any POST calls. We are receiving this error:
It seems that is not able to find the input parameters but we have defined them in the body:
Are we missing something? Do we have to create a swagger file with the definition of the endpoints?
Thank you!
Support
Hi @saguiarde.
Which version of ThingWorx are you running?  This issue has been reported for ThingWorx 8.3, but may affect later releases as well.  At this point, we don't yet have a target date for resolution but support is being dropping on the 8.3 version this month.
If you're running ThingWorx 8.4 or above, you may want to consider using Flow which has an SAP connector built in.
--Sharon
saguiarde1-VisitorAuthor
Thanks for the reply.
We are running version 8.5. Could you please send me the information where this issue has been reported?
Initially we started to use Flow but it is very buggy and thus not functioning as expected.
Thank you!
