11-Garnet
OK and Cancel Display
The display choice of OK and Cancel in the Edit Query Dialog of the composer should be put to discussion. Normally the OK option is to submit the changes and therefore should be green and get the check mark.
Please have a look at this.
slangleyAnswer
Support
Hi @gbirnzain.
The fix for this issue was delivered in 9.2.x.  Please check it out and if satisfied, please mark the Accepted Solution for the benefit of others with the same issue.
--Sharon
Support
Hi @gbirnzain.
Please feel free to post your idea on the ThingWorx Ideas forum.  This will allow others to vote for it which can improve its chances of being incorporated in a future release.
--Sharon
gbirnzain11-GarnetAuthor
11-Garnet
It's kind of not an idea. Therefore I will not put it in the Ideas forum.
But thank you for your effort.
Support
Hi @gbirnzain.
I found that we have an internal ticket opened for this.  There is not yet a target date assigned, but it has been accepted for a future release of the product.
--Sharon
slangleyCommunity ManagerAnswer
Support
Hi @gbirnzain.
--Sharon
