Jul 15, 2025 10:13 AM UTC
On reducing the font size it is ended up by having a scroll
I am using ThingWorx Platform Release 9.2 and DatecodeSP6
On reducing the font size it is ended up by having a scroll, instead of the font size getting reduced
    Catalina
    Community Manager
    Jul 15, 2025 10:29 AM UTC
    Hi @Rajadhurai
    Thank you for your question!
    I’d like to recommend to bring more details and context to your initial inquiry. For example:
    • Is the scroll appearing horizontally, vertically, or both?
    • Are you applying the font size change via custom CSS, widget properties, or a theme?
    • Does the scroll appear in a specific widget or across the entire mashup?
    Please add screenshot(s) to better understand what you are trying to do in your process.
    Please refer to this guideline to make your questions more likely to receive a quick and useful answer.
    Here's what a good question for Thingworx looks like.
    Thank you for your participation and please let me know if you need further assistance!
    Best regards,
    Catalina | PTC Community Manager
    Support
    Jul 18, 2025 3:04 PM UTC
    Hi @Rajadhurai
    Please provide further details of your use case.  Where are you reducing the font size?  In a mashup?
    You may already be aware, but you're running an older, unsupported version of ThingWorx.  It's possible the issue you're experiencing has been addressed in a more recent version of the product.   if you can provide some recreation steps, I can test it against a supported version.
    --Sharon
