One-Hot Encoding
I am currently working in ThingWorx Analytics and have categorical data as input. In order to try to enhance the accuracy it is common/recommended to try One-Hot Encoding(OHE) of the data. However, i don't think any of the opTypes are suitible for OHE, as this would require a vector as input. Has anyone tried to use OHE in ThingWorx analytics?
Best regards
cmorfinAnswer
Hi
Sorry for the delay, I was waiting for some answer from R&D on this.
It appears that one hot encoding is internally automatically applied to the field, though it depends on the model type.
This is not configurable, but used internally.
I have documented some more details about this at https://support.ptc.com/appserver/cs/view/solution.jsp?n=CS283787
Kind regards
Christophe
Hi
I don't think this is something we can use but I need to look into this and will post once I have more details
Regards
Christophe
PErhams1-VisitorAuthor
That would be great! Since OHE is a farily common way to adapt categorical input it is probably something PTC should consider implementing.
cmorfin19-TanzaniteAnswer
Hi
Kind regards
Christophe
