Opacity Blur Effect
Does anyone have a trick to make the images/text behind a Style Definition using Opacity to have a blur effect? I like the ability to have the opacity as it adds a nice look but I would like the make the content behind it also have a blurred effect.
Thank you,
Mike
    I also have this question. May be anyone found a solution in this 3 Years?
    In my case I would like to have a glass panel with blurred camera image in the background.
    Jonny
    You should be able to add the effects using custom CSS code in the mashup. The ability to add custom CSS was introduced only from ThingWorx 8.2+. Refer Custom CSS Help Center for more information
