OPC UA server connection to Thingworx Composer
Hello community,
For my current project, I need to implement a OPC UA server on top of  a Kuka robot and stream the process data to Thingworx composer. What would be the best way to implement this? Is there a OPC UA client implementation for Thingworx Composer that I could connect to the server?
Thanks a lot for advise!
@augmentor : PTC has OPC UA client extension available at MarketPlace for the purpose.
that has documentation attached as well on its usage and installation. Kindly follow that
Or you may use the OPC Aggregator (which features OPC-DA and OPC-UA clients) pointed out here https://developer.thingworx.com/resources/downloads/manufacturing-trial-editionand it's the replacement for the old OPC-DA agent and it may become the replacement to OPC-UA client on the marketplace too. OPC Aggregator it's based on Kepware which in theory it's the path to follow.
augmentor1-VisitorAuthor
Thanks, I`ll try both solutions and see what works best!
