Nov 19, 2017 4:50 PM UTC
Open popup on Event
I'm looking to open up an information popup within a mashup when an event happens.
I have a counter, when that reaches zero, I want the popup to open with some information.
Currently I have only found how to open the popup using the Navigation widget.
Any help would be appreciated.
PaiChungAnswer
22-Sapphire I
Nov 21, 2017 11:49 AM UTC
Wire the boolean into a Validation Widget to get an actual event that can fire the Navigation.
set the Widget to auto evaluate and again make it invisible
be sure to define a parameter for in the Widget configuration that you can wire the boolean to
after that in the expression just use inameofyourvariable == true
and then you can use the On True and On False events to trigger other services like Navigate
22-Sapphire I
Nov 20, 2017 11:01 AM UTC
The Navigate action that opens the pop-up can be initiated with a mashup event (vs. having to click the button)
so you can use the navigation widget, make it invisible, and fire it with an event.
csmith-211-VisitorAuthor
Nov 20, 2017 11:18 AM UTC
Thank you Pai. That's exactly what I was trying to do. I'll give it another shot this evening and comeback with any queries if that's ok?
I have a boolean variable in my thing data that's passed into the mashup. That's what I want to use to trigger the event.
