Nov 23, 2016 2:14 PM UTC
Open weather app tutorial problem
Hi Everyone
I am having a problem with the open weather app tutorial. I have followed the tutorial but i get an error when testing the code. I have created my own API key using the link in the tutorial. I didn't know if there may be an issue with having copied the code from the PDF and whether formatting has been lost.
See error below
Wrapped org.apache.http.conn.HttpHostConnectException: Connect to api.openweathermap.org:80 [api.openweathermap.org/178.62.207.82, api.openweathermap.org/178.62.223.38] failed: Connection timed out: connect Cause: Connect to api.openweathermap.org:80 [api.openweathermap.org/178.62.207.82, api.openweathermap.org/178.62.223.38] failed: Connection timed out: connect
And the code i'm using below
var stringLocation=location+" ";
var arrayLocations=stringLocation.split(",");
var lat=arrayLocations[0];
var long=arrayLocations[1];
//Modify the open weather url here if you are using your own API key
var params = {
  url: "http://api.openweathermap.org/data/2.5/forecast?lat="+lat+"&lon="+long+"&units=imperial" +"&type=accurate&mode=xml&APPID=75239107b41bd2c2a72e2e3c7b89b550" /* STRING*/,
  timeout: 160 /* NUMBER */
// result: XML
var xmlPage = Resources["ContentLoaderFunctions"].LoadXML(params);
var params = {
  infoTableName : "InfoTable",
  dataShapeName : "OpenWeatherFeed"
// CreateInfoTableFromDataShape(infoTableName:STRING("InfoTable"),dataShapeName:STRING:INFOTABLE(OpenWeatherFeed)
var result = Resources["InfoTableFunctions"].CreateInfoTableFromDataShape(params);
  var from_today_value=xmlPage.forecast.time[0].@from.substring(0,10);
  a.logger.warn("from_today_value= "+from_today_value);
for each (var item in xmlPage.forecast.time) {
  var row = new Object();
  var from_current_value=item.@from.substring(0,10);
  row.WindDirection = item.windDirection.@name;
  row.WindSpeed=item.windSpeed.@mps;
  row.WeatherTemp=parseFloat(item.temperature.@value);
  row.WeatherHumidity=parseFloat(item.humidity.@value);
  row.From=item.@from;
  row.To=item.@to;
  row.Title=xmlPage.location.name+" "+xmlPage.location.country;
  row.Precipitation=(item.precipitation.@type+" "+item.precipitation.@value)==" "?"NoPrecipitation":item.precipitation.@type;
  result.AddRow(row);
Thanks Matt
msuttonAnswer
Dec 22, 2016 12:36 PM UTC
Hello Everyone
Turned out the issue was with the firewall blocking access to the open internet here at work
Thanks Matt
Nov 29, 2016 9:14 PM UTC
Are you sure that is the right API Key? Also, have you made sure that everything rendered right, like even newlinee characters? I have had issues copying from PDFs into ThingWorx in the past
msutton1-VisitorAuthorAnswer
Hello Everyone
Thanks Matt
Dec 28, 2016 3:36 PM UTC
Can you mark this answer as correct to help others find the answer to their problems more easily? Thanks, and glad to hear you got it working!
