Apr 28, 2025 3:57 PM UTC
openstreetmap widget
Using thingworx 9.6 cloud hosted .
has anyone used the MarkerField field on that widget ?
I tried using this field as IMAGE and IMAGELINK format but seens not working in any way ...
there is no doc ... may be because it's not supprted any more?
I'm now using the markerformatting to change the marker (using an integer field to select a style through a state-definition), but would use a specific "image" field passed directly on the infotable data ...
iguerraAnswer
May 16, 2025 7:28 AM UTC
I found the problem looking into the extension code
The marker field on the grid data has not to be of type IMAGE or IMAGELINK, but a STRING with the image path like
/Thingworx/MediaEntities/MyMarker
In this way I can use any marker on the map, from the infotable data
Probably, on the extension code, should change the assignment of the path to '/Thingworx/MediaEntities/' + MarkerName , in order to have on the grid data an IMAGELINK data type .. better to use. Anycase with the string method can get what I need.
Bye
Rocko
Apr 29, 2025 6:50 AM UTC
Not sure if that helps, but some doc on the widget is linked here:
https://community.ptc.com/t5/ThingWorx-Developers/how-to-use-openstreet-map/m-p/991334/highlight/true#M68754
Also check
https://github.com/thingworx-field-work/ThingworxUICatalogue
this should come with an OSM example mashup.I don't know if it uses the markerfield though.
iguerra16-PearlAuthor
Apr 29, 2025 7:50 AM UTC
I imported the GitHub package and example, unfortunately it's not using MarkerField
The markers in this demo are fixed and set on the widget style section
Apr 30, 2025 4:24 PM UTC
Hello @iguerra ,
The open Streets Extension, is not supported.  I have looked at this Extension previously. One of the issue I found was the library which supports Open Streets has been updated. It would be wise to make sure your version is up to date.
If you have a test case which you can export (as XML). I will take a look and see if there is any recommendation
Pehowe
