Dec 11, 2024 11:55 AM UTC
Options in drop-down widget are overlapping a second drop-down
Currently we are using responsive containers in thingworx composer design.
When clicked on second dropdown, its options are overlapping with first down
Expectation is to get options just below its own dropdown. Please help us to achieve this.
javed_aAnswer
Dec 11, 2024 12:13 PM UTC
If you are using DropDown widget, try changing value for ListMaxWidth.
Ensure there is no external CSS getting applied. Alternatively, you can try with List widget if it is the same behavior.
javed_a13-AquamarineAnswer
Dec 17, 2024 12:11 PM UTC
There is no property called ListMaxWidth in Thingworx 9.3 and there is no external CSS present.List widget is not behaving like dropdown widget.Thanks
Dec 17, 2024 1:00 PM UTC
Okay, I had checked this option in 9.4.6
Support
Dec 17, 2024 5:17 AM UTC
Hi @krishnakomal211 ,
It appears that there is a reply to answer your question.  For the benefit of other Community Members who may have the same question, it would be great if you could designate it as the Accepted Solution.
In the event that this response did not answer your question, please post your current status so that we can continue to support.
Thanks for using the PTC Community!
Charles
Dec 24, 2024 9:20 AM UTC
I am still waiting for a solution for this. Thanks
Support
Feb 17, 2025 2:07 AM UTC
Hi @krishnakomal211, it seems that the workaround functionality has been implemented in ThingWorx 9.4.6.
Since the standard support for ThingWorx 9.3.x has ended, you may consider upgrading to the latest support version.
Check the Product Release Calendar for more information on ThingWorx versions.
Hope it helps!
