Pareto Chart - line value or label clicked event
Hello. i have the following pareto with small values that i cannot use the 'SeriesClicked' event because the values are so small. is there a way to click the cumulative line 'dot' or the label and trigger an event?
@LP_10027711 Seems you are using Pareto Chart widget. Have you tried zoom setting to enlarge the display of dot matrix content?
