7-Bedrock
Password thingworx
When I press enter after thingworxPostgresqlDBSetup command prompt, it says password not supplied. What is wrong there?
nmillesonAnswer
Looks like you need to use the -r to tell it the password.  Did you specify that when running the file?
So you'd add something like:
-r myP@s5W0rd
Nick
@SA_10373213 ,
Can you paste the command you are running?  Also, is this Windows or Linux?
-Nick
7-Bedrock
echo off
REM Copyright (c) 2015, PTC Inc. All rights reserved
REM PostgreSQL server psql runner script for Windows
SET server=localhost
SET port=5432
SET database=thingworx
SET tablespace=thingworx
SET tablespace_location=C:\ThingworxPostgresqlStorage
SET adminusername=postgres
SET thingworxusername=twadmin
SET managedinstancename=""
for /f "delims=" %%a in ('chcp ^|find /c "932"') do @ SET CLIENTENCODING_JP=%%a
if "%CLIENTENCODING_JP%"=="1" SET PGCLIENTENCODING=SJIS
if "%CLIENTENCODING_JP%"=="1" SET /P PGCLIENTENCODING="Client Encoding [%PGCLIENTENCODING%]: "
:LOOP
IF NOT "%1"=="" (
IF "%1"=="-h" (
SET server=%2
SHIFT
IF "%1"=="-H" (
SET server=%2
SHIFT
IF "%1"=="-p" (
SET port=%2
SHIFT
IF "%1"=="-P" (
SET port=%2
SHIFT
IF "%1"=="-d" (
SET database=%~2
SHIFT
IF "%1"=="-D" (
SET database=%~2
SHIFT
IF "%1"=="-t" (
SET tablespace=%~2
SHIFT
IF "%1"=="-T" (
SET tablespace=%~2
SHIFT
IF "%1"=="-l" (
SET tablespace_location=%~2
SHIFT
IF "%1"=="-L" (
SHIFT
IF "%1"=="-a" (
SET adminusername=%~2
SHIFT
IF "%1"=="-A" (
SHIFT
IF "%1"=="-r" (
SET password=%~2
SHIFT
IF "%1"=="-R" (
SET password=%~2
SHIFT
IF "%1"=="-u" (
SET thingworxusername=%~2
SHIFT
IF "%1"=="-U" (
SHIFT
IF "%1"=="-m" (
SET managedinstancename=%2
SHIFT
IF "%1"=="-M" (
SHIFT
IF "%1"=="--help" (
echo usage: thingworxPostgresDBSetup.bat [-h ^<server^>] [-p ^<port^>] [-d ^<thingworx-database-name^>] [-t ^<tablespace-name^>] [-l ^<tablespace-location^>] [-a ^<database-admin-user-name^>] [-r ^<database-admin-password^>] [-u ^<thingworx-user-name^>] [-m ^<azure-managed-instance-name^>]
GOTO :END
SHIFT
GOTO :LOOP
echo Server=%server%
echo Port=%port%
echo Database=%database%
echo Tablespace=%tablespace%
echo Tablespace Location=%tablespace_location%
echo Admin User=%adminusername%
echo Thingworx User=%thingworxusername%
echo Azure Managed Instance=%managedinstancename%
IF NOT [%password%] == [] (
SET PGPASSWORD=%password%
echo Start Execution
REM Run psql
IF %managedinstancename%=="" (
psql.exe -q -h %server% -d postgres -U %adminusername% -p %port% -v database=%database% -v tablespace=%tablespace% -v username=%thingworxusername% -v tablespace_location=%tablespace_location% -f ./thingworx-database-setup.sql
pause
) else (
psql.exe -q -h %server% -d postgres -U %adminusername%%managedinstancename% -p %port% -v database=%database% -v tablespace=%tablespace% -v username=%thingworxusername% -v tablespace_location=%tablespace_location% -f ./thingworx-database-setup-managed.sql
pause
echo End Execution
:END
-Window
nmilleson17-PeridotAnswer
-r myP@s5W0rd
Nick
Support
Hi @SA_10373213.
The script should prompt for the password.  Have you made changes to the script?  It's not recommended to do so.  You can find the installation instructions here.
If you continue to have issues, we can open a case to see what may be going on.
--Sharon
