Jul 28, 2026 1:09 PM UTC
PATCH HTTP Request in Thingworx
Hi all,
I am trying to integrate Thingworx with a Dataverse table using API calls. I am trying to update a row, but that requires a PATCH call. The content loader functions only support GET, POST, PUT, and DELETE. Has anyone found success for making a PATCH call? I have tried overriding a PUT call as PATCH but that was not supported with the Dataverse API.
TWX Version 10.0.3
nmutterAnswer
Jul 31, 2026 12:31 PM UTC
I tried it with 10.1 and get the same error. Most likely due to TWX 10 which uses new java version.
I see a github issue regarding TWX 10:https://github.com/thingworx-field-work/ContentLoaderExtendedTWX/issues/6
Guess you could try to build a new version with the adaptions they mentioned in the issue and get it working.
Rocko
Jul 29, 2026 6:19 AM UTC
Jul 30, 2026 7:50 PM UTC
Rocko, thanks for this link. Trying it out currently. Currently getting the below error when trying a simple GET call. I know it is an extension, but could there be an issue with ThingWorx version compatibility? May just need to keep testing to see if I am missing something
Message :: 'org.apache.http.impl.client.CloseableHttpClient com.thingworx.common.utils.HttpUtilities.createHttpClient(java.lang.String, byte[], java.lang.Boolean, java.lang.Double, java.lang.Boolean, java.lang.String, java.lang.String, java.lang.Boolean, java.lang.String, java.lang.Integer, java.lang.String, javax.net.ssl.SSLContext)'
Rocko
Jul 31, 2026 8:59 AM UTC
Compatibility could be an issue, you’d have to verify with the developer.
Support
Aug 6, 2026 12:32 AM UTC
Hi ​@JK_10744682,
Currently, ThingWorx only supports GET, POST, PUT, and DELETE methods.
However, the following article suggests a possible workaround by manually adding the required header:
https://www.ptc.com/en/support/article/CS375549
If that approach does not work, you may want to explore available customer extensions. In addition, feel free to submit an enhancement request through the ThingWorx Ideas portal:
https://community.ptc.com/t5/ThingWorx-Ideas/idb-p/thingworxideas
Aug 6, 2026 11:58 AM UTC
This unfortunately did not work for the API I am trying to connect to, but I was able to find a workaround to use PUT with the API (Dataverse)
Aug 6, 2026 12:01 PM UTC
I was not able to get PATCH calls working in thingworx, but just in case anyone else is ever using the Dataverse API, PUT can be used but only to change a single value for a single entry at a time. If trying to change multiple values, it will give an error saying the operation isn’t allowed. In my use case this worked fine since I only need to update a single value at a time anyways.
Aug 6, 2026 12:03 PM UTC
For anyone curious on using PUT for dataverse API, it can be used but only for changing a single value for a single row/entry. In my case this works just fine
