Jan 27, 2021 3:27 PM UTC
PDF Extensions does not show all elements
Dear community,
I tried to use the PDF Extension as this functionality is exactly what my key user is asking for. Unfortunately it is not working well for me, please refer to the attached files:
- TimeReport_20210127_4.pdf is the output of the CreatePDF function
- TimeReport_20210127.png is an actual screenshot
As you can see the box is printing well but the chart and the grid are missing. Perhaps important is that both elements are Extensions, the Grid is the Grid-Advanced and the Time Series Chart is a fork of myself from the Time Series Chart of originally Thingworx 8.3.
What I have tried so far:
  • Tested every option in CreatePdf:
    • Rotated90Deg true/false
    • Resolution different up to 1920*1080
    • DebugUsefontconfig true/false
    • ScreenshotDelaySecond up to 30s (which should not be necessary because the printed numbers are correct)
  • Assigned Admin privileges to the AppKey (even though a regular user also has all necessary permissions, tested and verified)
I am very certain my URL is correct because I can just copy+paste it to the browser and it shows up for me in all its incomplete ugliness.
Our Thingworx version is 8.4.4 and I am using Chrome 87.0.4280.88 if that makes any difference.
I am aware this Extension is not officially supported and perhaps even deprecated but I have not found any replacement and as said above, it would suite very well to our use case.
I have seen several topics in the community but non of the suggested solutions helped me. Perhaps @vrosu sees this and is able to help me out here.
Thank you
Benny
BennyB16-PearlAuthor
Jan 27, 2021 3:29 PM UTC
@VladimirRosu_116627
Sorry, used wrong user tag in my original message
Jan 28, 2021 8:25 AM UTC
Hi!
After looking at what you tried, I don't have other suggestions. The delay would be the first thing I would try to modify. I haven't seen until now incomplete renderings.
I suggest the following:
-trying to recompile the extension with the latest jBrowserDriver & selenium libraries.
-trying to setup your screen resolution exactly to the default of the extension (1366x768) and then trying to access the page manually to check if it's rendering correctly (even if I see you tried to set it manually to FHD in the extension, maybe it's something wrong with that option in my code)
Jan 28, 2021 12:00 PM UTC
Hi @VladimirRosu_363587 and thank you very much for your reply.
Concerning your suggestions:
- Unfortunately I don't have the setup to compile the Extension myself. I took the zip file that came along with the github download in the build folder. But I will try to find a way to achieve this.
- I tested a lot with different resolutions, including using the default resolution and accessing the page with all kind of different resolutions. I will keep testing here but have little hope to find something here.
Thanks again, I will keep you posted.
Benny
Jan 28, 2021 12:04 PM UTC
Hi Benny,
If you download that github repository where you downloaded the importable extension, you will have your source code. I added it there especially for cases like this, when the users require small modifications.
However, that requires also some small Java knowledge, in the sense of using Eclipse - not sure if that's something in your arsenal.
