Persistent infotable property
Hi
I have Persistent infotable proeprty for my device.
I understood that persistent property is store data even if device goes to offline.
but I add some rows on my infortable and disconnect, reconnect device.
rows on infortable are disappeared.
Is is all right?
How can I maintain infortable's data?
raluca_edu
You need to follow the approach from this article: https://www.ptc.com/en/support/article?n=CS227531
Recommendation is to clone infotable, perform the modification and after assign again the infotable to the original one.
Hope it helps,
Raluca Edu
raluca_edu
Hope it helps,
Raluca Edu
Thank you!
It resolve my problem 🙂
