Hi @svisveswaraiya_285988 ,
I have tested it and the only way that worked for me to show the full text of the legend was to select LegendOrientation as Vertical instead of Horizontal.
Hope it helps,
Hope it helps,
Hi @Ciprian-Traian ,
Thanks for your swift response.
The legend orientation is already set in vertical. But still this occurs.
Hello @svisveswaraiya_285988
Can you please help me with version of your thingworx?
I tried it on 8.5.7 and its working fine for me.
Om DUkiya
Hi @odukiya ,
I am using  8.5.4 version of thingworx.
Shalini V.
If you are still facing the issue than please share the sample entities to understand it better.
Om DUkiya
