Pie Chart Widget Extension
I want to modify the appearance of Pie Chart Widget. My system is not showing icon, .js ans .css files which should be present in ../Thingworx/common/thingworx/widgets/ for Pie Chart.
Can anyone provide those files as zip.
slangleyAnswer
Support
Hi @MananKumawat.
It doesn't appear this functionality exists out of the box, but it is being considered for a future release.
You could create a new widget by starting with the one that comes with the product and make the needed customizations.  Refer to the ThingWorx Extension Development Guide for assistance.
If you have further questions, please let us know.
--Sharon
Support
Hi @MananKumawat.
What type of modifications are you needing to make?  There are several changes that can be made from the Properties panel in the lower left of the Mashup builder screen.  Depending on the version of ThingWorx you're running, you may also be able to use CSS for making the changes desired.
--Sharon
Hi @slangley ,
I'm currently working on 8.4.2. Want to show the percentage of each segment without hovering over it.
Support
Hi @MananKumawat.
If you feel that I have answered your question, please mark the previous response as the Accepted Solution for the benefit of others with the same question.
--Sharon
