May 17, 2017 1:33 PM UTC
Platform Extension Dependencies
In developing an extension for the marketplace, it is acceptable for an extension to have a dependency on another extension? Additionally, is there a particular way this should be done? I presume distributing the existing extension along with our extension would not be allowed. The specific case I'm considering is the free MQTT extension.
posipovaAnswer
20-Turquoise
May 17, 2017 2:48 PM UTC
You may use the existing extension (in this case, MQTT) as a dependency. One will simply install the MQTT extension first, then the one you develop (ensure to assemble the metadata file correctly). I'm attachign some documentation on custom extensibility.
posipova20-TurquoiseAnswer
20-Turquoise
