plotting graph using json object
Consider I have a series of json data as follows,
[{"f":"450.0","a":"746.0"},{"f":"453.0","a":"1119.0"},{"f":"456.0","a":"746.0"}]
with f denoting frequency and a represents acceleration.
How to plot a graph for acceleration in x axis and frequency in y axis ?
How to write a service for the same ?
My first thought would be to convert your JSON into an Infotable so that you can use it in your preferred graph widget.
Here is one way you can convert your JSON into an Infotable: PTC support article
Hope this helps.
Jens
