Populating Network Trees with InfoTables
Hi All
Is it possible to populate network trees only from InfoTables and not using a Network Entity or Things?
The code I have attempted is as follows:
Inputs: Name - STRING.
var params = {
maxItems: undefined /* NUMBER */
// result: INFOTABLE
var connections = Things["TestDataTable"].GetDataTableEntries(params);
var params = {
infoTableName : "InfoTable",
dataShapeName : "TestNetworkDataShape"
// CreateInfoTableFromDataShape(infoTableName:STRING("InfoTable"), dataShapeName:STRING):INFOTABLE(AtlasCustBooleanDS)
var networkInfoTable = Resources["InfoTableFunctions"].CreateInfoTableFromDataShape(params);
var entry;
var i = 0;
var row = new Object();
var eachRow;
row.from = undefined;
row.to = Name;
row.description = Name;
row.connectionType = "Contains";
networkInfoTable.AddRow(row);
row.from = Name;
for each(entry in connections.rows)
//eachRow = connections.getRow(i);
if (entry.Name == Name)
row.description = row.to;
row.Name = Name;
i++;
var result = networkInfoTable;
Any feedback/sugestions would be highly appreciated.
Ashley
