Jan 31, 2026 5:37 PM UTC
Popup Mashup on Specific Data Series in Bar Chart
I’m using the bar chart widget with 3 data series. Is it possible to configure a navigation mashup popup so that it appears only on one particular data series (instead of the whole chart)?
slangleyAnswer
Support
Feb 3, 2026 9:19 PM UTC
Hi @ST_14485832.
I don't think it's possible to configure a navigation mashup popup to appear only on one particular data series within a bar chart widget in ThingWorx. The functionality typically applies to the entire chart rather than individual series.
You might want to check out the widgets available from IQNOX to see if they have an alternative solution.  I think they also do custom widget development if you are inclined to go that route.
--Sharon
slangleyCommunity ManagerAnswer
Support
Hi @ST_14485832.
--Sharon
