Popup widget for Notification
- 4 replies
- 2342 views
- Translate All
I need a workaround to display the latest 5 notifications , which I have in an infotable(only a way to visualize the data is required). What I need is a widget / workaround to display the notifications in a small popup in the same mashup and at the end of the notifications I would like to have a button to navigate to another mashup. I have used Mashup as popup and it is navigating to a popup page where the popup comes at the middle. I need it to be in a corner.
To see exactly what I mean I am attaching an image which show the visualization
Kindly suggest any workarounds or widgets which I can use to make it look like the popup in the image.
Thank You
