Postgres Persistence provider [Data store unknown error]
I tried to create Postgres persistent provider to store stream and value stream data.
I am able to connect DB( checked using isConnected service) but not able to store and retrieve data, when I use the default service of add stream-entry I am not getting any errors. but I tried to access row count by calling GetStreamEntryCount then I got the error below-mentioned error message.
I am getting errors like this :
Unable to Invoke Service GetStreamEntryCount on Demo.Manual.STREAM : com.thingworx.common.exceptions.DataAccessException: [1,018] Data store unknown error: [Error occurred while accessing the data provider.]
JimwangAnswer
@sabharees ,
You can refer to the article CS262935 (https://www.ptc.com/en/support/article/CS262935) to setup 2nd persistence provider.
The key steps are:
1> Create a DB User and grant the permission
2> Create a new Database
3> Grant enough permission for the new User to access to the database
4> Create Thingworx DB schema
5> In Thingworx Composer, Create a 2nd Persistence Provider and Configure the connection
Hi @sabharees ,
This issue seems similar resolved in the given article.
Kindly check and revert back the results Similar case .
Regards
Bhawna
sabharees15-MoonstoneAuthor
Hi @bchaudhary_448008 ,
Thanks for the link. But still, I am not able to resolve these issues.
Also in my application log, I found this error log: Transaction has been marked as a failure for request /Thingworx/Things/Test.PP.Stream/Services/QueryStreamEntriesWithData.
Sab.
Hi @sabharees ,
Can you please attach the application logs?
Regards
Bhawna
