pshashipreetham
Postgres to InfluxDB Migration
There is a situation where DataTables Data(Which is in Postgres) needed to be Migrated to the InfluxDB, such that going forward InfluxDb Streams will be used in DataTables. So, is there any best Practices by PTC provided ?
@VladimirN @AnnaAn @paic @slangley @CarlesColl @c_lowy
Shashi.
pshashipreetham
So,
There is no particular way @slangley  mentioned. We need to write a service that adds each row in DataTable to the Stream(Created using Influx Persistence).
Example Code:
for (i = 0; i < FilteredAlarmsBasedOnTank.rows.length; i++)
	var row = FilteredAlarmsBasedOnTank.rows[i];
	var data = {
		Alarm: row.Alarm,
		ThingName: row.ThingName,
		Facility: Thing.Facility
	values.AddRow(data);
	result.AddRow(data);
	Things["TankAlarm"].AddStreamEntry({
		timestamp: row.Date,
		source: Thing.name,
		sourceType: "Thing",
		values: values
	values.RemoveAllRows();
Shashi Preetham || +91 8099838801 || shashi@psptechhub.com
Support
Hi @pshashipreetham.
Have you reviewed the information available in the ThingWorx Help Center?
--Sharon
pshashipreetham
Hi @slangley ,
Gone through all the Docs present in the Thingworx help center, found nothing !
Shashi
pshashipreetham
pshashipreetham19-TanzaniteAuthorAnswer
So,
Example Code:
	var data = {
		Alarm: row.Alarm,
		source: Thing.name,
		values: values
hi, please can you explain this line:
Second question: why do you add to the stream and then remove all rows from values infotable?
