Dec 14, 2018 6:24 AM UTC
PostgreSQL With Procedural
Hello everyone,
Can I write my procedural language thing in postgresql??
like this
SELECT
Asset_id
FROM
"Alerts"
FETCH FIRST [[RowByIndex]] ROW ONLY;
and for rowbyidex,  I assigned it as input from property
Dec 14, 2018 6:58 AM UTC
You can write stored procedural in External Database, and call it from TWX in SQL services. But if the Postgresql is used as persistence provider, it doesn't help.
ShanuGarg1-VisitorAuthor
Dec 14, 2018 8:40 AM UTC
So,
In which Persistance Provider It will going to help?
Dec 17, 2018 2:05 AM UTC
The function you want only works in SQL commands, so for any external Database connection, it would work, for any Persistence provider, it won't.   (Meaning that whatever Persistence Provider you choose, it can work in the External Database connection you create for the server)
The data connection logic in Persistence Provider is limited by TWX design, you don't have much choice for customization.
