PostJSON in ThingWorx 9.0 Extension SDK
Has anybody been successful using the ContentLoader functions in TWx 9.0 Extension SDK?  I've been following this example and this javadoc but I keep getting a null pointer exception.  Just to test my sanity, I used the same url, header, and content information inside a Composer service and I was successful.  I've attached the stack trace and the code I'm using is:
public Boolean myService() throws Exception {
	Boolean verify = false;
	ContentLoader verifyCheck = new ContentLoader();
	String url = "https://postman-echo.com/post";
 JSONObject content = new JSONObject("{\"meta\":{\"key\": \"" + "abc" + "\"}}");
 String username = null;
 String password = null;
 JSONObject headers = null;
 Boolean ignoreSSLErrors = null;
 Boolean withCookies = null;
 Double timeout = null;
 Boolean useNTLM = null;
 String workstation = null;
 String domain = null;
 Boolean useProxy = null;
 String proxyHost = null;
 Integer proxyPort = null;
 String proxyScheme = null;
 try {
 _logger.warn("URL in myService(): " + url.toString());
 _logger.warn("Content in myService(): " + content.toString());
 verifyCheck.PostJSON(url, content, username, password, headers,
 ignoreSSLErrors, withCookies, timeout, useNTLM, workstation, domain, useProxy,
 proxyHost, proxyPort, proxyScheme);
 catch(Exception e)
 	StringWriter sw = new StringWriter();
 	PrintWriter pw = new PrintWriter(sw);
 	e.printStackTrace(pw);
 	_logger.error("Exception in myService(): " + sw.toString());
		return verify;
nmillesonAnswer
@slangley ,
Thanks for the reply.  I believe I found the issue.  In the example that I linked, all of the Boolean values are set to null.  I changed them all to false instead and that seems to have fixed the issue.  The PTC example may need to be updated.
Support
Hi @nmilleson.
We're working internally to answer your question and will respond back as soon as we have more information.
--Sharon
nmilleson17-PeridotAuthorAnswer
@slangley ,
Support
Hi @nmilleson.
Thank you for the follow-up!
I will pursue getting the instructions reviewed for update.
--Sharon
