Jan 31, 2018 4:26 PM UTC
Print button.
How to print the  mashup using a button?
Please provide some documentation or some instruction on how to work on it.
V.Shalini.
Feb 1, 2018 10:21 AM UTC
shalini visveswaraiya​: You can review the existing thread with a sample Print Button extension and see if it works for you.
-Durgesh
Feb 1, 2018 10:31 AM UTC
Hi Durgesh Patel,
I tried that but it doesnt work for me.
On import it throws error.
How should I proceed?
Feb 1, 2018 10:56 AM UTC
shalini visveswaraiya​: At this moment, we do not have a standard extension with this functionality so you might need to build a custom extension with required functionalities.
-Durgesh
Ascherer17
Mar 29, 2018 4:58 PM UTC
If you are looking to bring up the browser print functionality (like when you press CTRL+P), I was able to get this to show up using a Link widget with the SourceURL property set to:
<a href="#" onclick="window.print();return false;">Print this page</a>
When you click the link in the mashup, it pulls up the browser's print dialog.  I was using Thingworx 7.1.
Apr 5, 2018 12:48 PM UTC
Hello, V.Shalini.
Have the posts by Durgesh helped you resolve this issue? If so, please mark this as an Accepted Solution for the benefit of the rest of the Community. If there is still an issue, please let us know.
-- Craig A.
Ascherer17
Sep 4, 2018 3:44 PM UTC
You can also use an Expression widget with "print()" in the Expression field (no quotes " ").  Then trigger the expression using a button.
Support
Nov 27, 2018 9:36 PM UTC
Hi @svisveswaraiya_285988.
If one of the previous posts provided a solution to your question, please mark it as the Accepted Solution for the benefit of others with the same question.
--Sharon
