Printer Data in Thingworx
Hi this is peter
How can i get printer data's in Thingworx using KEPServerEx.
slangleyAnswer
Support
Hi @Peter_Raj.
This article from our knowledge base may be helpful.
If you are running into issues, we will need the following:
  • Versions of ThingWorx and KEPServerEX
  • Logs from both products
--Sharon
slangleyCommunity ManagerAnswer
Support
Hi @Peter_Raj.
--Sharon
Support
Hi @Peter_Raj.
If the previous response helped to find an answer to your question, please mark it as the Accepted Solution for the benefit of others on the community with the same question.
--Sharon
