problem accessing my properties from within javascript
I am using the following version of Thingworx: 5.0.0.425. I have created several things from the Thing Template: RemoteThingsWithTunnelAndFileTransfer, On each one of these things I created a couple of properties: country and vncpassword, I have given each one of these properties a default value and a regular value. Inside a service defined in a thing template I am using the following code to retrieve all the properties from these things:
var implementingThings = ThingTemplates["RemoteThingWithTunnelsAndFileTransfer"].GetImplementingThingsWithData();
for (var x = 0; x < implementingThings.getRowCount(); x++) {
var row = implementingThings.getRow(x);
if (row.description != ''){
var newRow = {};
newRow.thingName = row.name;
newRow.desc = row.description;
newRow.lastTransferDate = row.lastConnection;
if (row.isConnected){ newRow.isConnected = "/Thingworx/MediaEntities/Connectedbut"; }
else newRow.isConnected = "/Thingworx/MediaEntities/Disconnectedbut" ;
newRow.country = row.country;
try{
newRow.vncpasswd = row.vncpasswd;
} catch (err){ newRow.vncpasswd = ''; }
result.AddRow(newRow);
The values for country and vncpasswd are being returned as undefined for each one of the things. Is this is a bug or am I doing something wrong?
