Problem Connecting to localhost mysql
I am facing issue while adding a configuration thing. After saving it, the properties section isConnected is always false.Can you help me on this
Can you share the JDBC setting from configuration ? Make sure the JDBC connection string,DB user name and password are correct there .Also is there any error in Application logs that is pointing to exact problem in configuration ?
challa1-VisitorAuthor
It is a permission issue. Solved it..Thanks
Emeritus
Hi @challa
Happy to see your issue was resolved.  For the benefit of the Community, perhaps you could provide some further detail on the Permissions which caused the issue and indicate as Accepted Solution.
Thanks!
Leigh
