Problem creating and importing extension in thingworx 8.4
- 2 replies
- 1332 views
- Translate All
We are trying to publish our customizations as an extension but we run into issues with some of our Things.
The problematic Things have locally bound properties and when we create an extension containing those things the error log shows errors like these:
[context: Extension Exception][message: Error parsing C:\Program Files (x86)\ThingworxMSSQL-1.2.0-SNAPSHOT\ThingworxStorage\extensions\temp\Support_3183c8b2-84b6-4642-93e9-8b62d370a52b\Support\Entities\Downloads\Things_TomTestLinkedPropertiesThing.xml: (64, 64): cvc-complex-type.3.2.2: Attribute 'aspect.source' is not allowed to appear in element 'PropertyBinding'.]
I tried manually removing the attribute but then the validation fails on aspect.startType or aspect.tagAddress.
I created a simple thing with one property locally bound to cleanupoldsessionstimer, exported it to source control entities and created an extension using Eclipse and it already fails. You can find the exported thing and generated Extension attached to this post.
Any help as to why this is happening or what I am doing wrong would be much appreciated.
