Problem defining state definition in thingworx 8.4.3
Hello, I want to create state definition for my shape. but I am only be to define only two types. Please refer the following image. I want to define a style for a range of values. Eg - Green for 1, red for 0 and yellow for  greater than 2
PaiChungAnswer
22-Sapphire I
If just 0/1 yes String/Value
You only define for either 0 or 1 and the other one will be default
@gourinaik98
If you need to achieve
you can do it by using a String/Value state instead of a Numeric one.
Set the first state to String/Value 1 and the desired style
Set the second state to String/Value 2 and the desired style
Set the default state to the desired style
Hope this helps
Christophe
22-Sapphire I
Use the check+ or if you already clicked the check use the Add to add an additional range cut off.
I tried that, it still shows less than or less than equal to only
22-Sapphire I
Correct, that is how it is intended.
Your state definitions for number ranges always has to be defined with the approach of
a < b <= c < default
the default state will be anything above the last state you define.
