Problem running Analysis Events
- 3 replies
- 2637 views
- Translate All
I am encounring errors when trying to run analysis based on Events, i've published my model and when i test it i get results as i should (image 1) but when i map the data and enable the event i keep getting this error :
Throwable Error Executing Event Handler for event Type.Thing:Entity.TW.AnalysisServices.AnalyticsServer.AnalyticsServerConnector:Event.JobResultsAvailable : nul
on the application Log and results are returned too the mapped Data.
If someon can provide some help in the matter that would be great.
Thenk you.
