problem to getting The Thing through service?
var params = {
  maxItems: undefined /* NUMBER */,
  nameMask: undefined /* STRING */,
  query: undefined /* QUERY */,
  thingTemplate: "Vehicle"/* THINGTEMPLATENAME */,
  tags: undefined /* TAGS */
// result: INFOTABLE dataShape: RootEntityList
var result = Resources["SearchFunctions"].SearchThingsByTemplate(params);
I am using above service to collect all thing which is implemented through the template.i am able to get things. but i am not able to get all the thing which is implemented by the template.
can any one help me?
Hi dinesh s​,
Does the user running the Service have visibility Permission to the Things which are not showing up in the result?
ds-211-VisitorAuthor
hi Ankit,
      i am login through  Administrator. actually i am not getting around few things which i was implemented through the template.
Is any other reason is there. am not getting...
thanks
Dinesh
dinesh s​,
I just tested it on my local Instance 7.3.2 and it worked fine.
Could you please answer following:
1. Is there any difference (Permissions/Tags/Project etc) in the Thing which shows and the Thing which does not show?
2. Any details/error in Application/Script logs.
3. Try using GetImplementingThings Service.
Example: var result = ThingTemplates["YourThingTemplateHere"].GetImplementingThings();
