Hello @MD_10263895 ,
pls find the attached article for your refrence:
https://www.ptc.com/en/support/article/cs233537
https://www.ptc.com/en/support/article/cs201191
Kindly revert back if issue persists.
Regards
Bhawna
How can i get cutomer id? I haven't customer id.
Are you not able to access the article?
Try using with the same that you are using for logging into community .
Regards
Bhawna
