Jun 24, 2019 3:07 PM UTC
Problems with Alerts History
Hello guys,
I'm facing a strange problem.
There is a thing with some properties that have Alerts configured.
If I set manually some of these properties to "TRUE" the event of Alert works and the History populate normally.
On the other hand when a service manage automatically the Alerts, the properties change, the Alerts be active, but the history doesn't populate the infotable.
Could you help me, please?
Thanks.
Christyam
22-Sapphire I
Jun 24, 2019 4:11 PM UTC
What do you mean by a service manages it? What does the service do?
Did you check the log for any error messages?
csilva11-VisitorAuthor
Jun 24, 2019 5:17 PM UTC
Thanks @PaiChung
Well, imagine a property that has an alert configured and its name is "Property1".
Now, imagine a service named as "Service1" that has some "if/else" and an attribution like "me.Property1 = true;".
My symptom is, if I manually put "true" to  "Property1" the alert is activated and when I test the service "QueryAlertHistory" the infotable is normally populated.
If I let "Service1" run, "Property1" changes, but the Alert History doesn't populated as well.
I checked again the Monitor and there are no errors related.
22-Sapphire I
Jun 25, 2019 1:10 PM UTC
That sounds like a bug, because that seems to imply the Alert isn't firing, or perhaps even data change isn't firing.
You can test if datachange is firing by just creating a subscription and putting in a logger statement.
I would put in a support ticket.
