progress gauge responsive
Hi there,
Does someone has a responsive progress gauge to share with me?
I have just a static progress gauge
slangleyAnswer
Support
Hi @leokeinsfeld.
It's possible that there could be some compatibility issues with the version of ThingWorx you are running.  Unfortunately, this is not a widget that is supported by PTC so we are unable to validate compatible versions.  Perhaps the developer that provided the widget can offer some guidance if you can provide further details around the version of ThingWorx you are running and the issues you are encountering.
As an alternative, you can create your own custom widget with the needed functionality.  You may refer to this page from the ThingWorx Help Center for assistance to write your own widget/extension.
Thank you for participating in our community!
--Sharon
Support
Hi @leokeinsfeld.
Please check out this post for resolving your issue.
--Sharon
Hi @slangley
I have tried to use the widget shared in this topic, but it do not work well.
