6-Contributor
Project entity visibility hiding among different teams
We have a single instance to develop to projects. Our requirement is that developers from two teams should not be able to edit each others entity. I tried by creating two projects(Project1 and 2). Then I created two Oeganization(ProjOrg1 and ProjOrg2). Then I created two different user groups(Proj1Dev and Proj2Dev) and assigned them in individual Organizations. In the Project level I changed permissions in Visibility- to individual Org(Project1 is assigned ProjOrg1 and in runtime.design time only Proj1Dev User group is assigned). Still I can see that both the User groups can see each other entities and edit. How can I achieve this separation ? I,m using Thingworx 8.5.6
Hello @SM_9588025 ,
You would have your Organization (ProjOrg1 and ProjOrg2) with visibility permissions.
Then the user groups(Proj1Dev and Proj2Dev)  where you grant runtime access control and design time.
Hope it helps,
What visibility should I give in Projorg1 and Projorg2. They are organizations that should have visibility to the entities in those two projects. At user group to whom I will give permission at runtime and design.  Can you explain
