Aug 5, 2026 7:43 AM UTC
Project Import failed via XML single file
Hi All,
While importing whole project to new server getting below error:
Already checked:
Thingworx version is same:9.5.1
All required/dependent extension available
Application log Error:
Unable to process import org.json.JSONException: A JSONObject text must begin with '{' at 1 [character 2 line 1]
Javed Akhtar
Aug 5, 2026 8:50 AM UTC
​@VladimirN
XML does have user details; I remove that and it worked.
<Users>….. </Users>
Aug 5, 2026 8:02 AM UTC
Check for spaces before { in file.
Aug 5, 2026 8:14 AM UTC
​@VladimirN Thanks!
First line is generic XML tag only and content starts with below block, I don't see any space, any other possible cause:
<![CDATA[{
But I saw below pattern will that be an issue: here there is space between [ and {
"Services" : [ {
However, I tried removing space in-between for start and close, still same error.
JavedAkhtar10-MarbleAuthorAnswer
​@VladimirN
<Users>….. </Users>
