Nov 17, 2026 8:09 AM UTC
PTC Cloud ThingWorx: Using a Custom CA Certificate in jssecacerts for Multi-Site Optix Edge MQTT SSL Authenticatio
Environment Details:
  • Platform: ThingWorx 10.0
  • Integration Protocol: MQTT (using ThingWorx MQTT Extension)
  • Edge Device: Optix Edge (acting as MQTT broker/client per site)
  • Authentication Current State: Username and Password authentication (Tested & Working)
  • Target Security State: SSL/TLS Certificate-Based Encryption and Device Authentication
Scenario & Architecture Overview:
We are setting up edge device connectivity from multiple remote sites to our PTC  ThingWorx instance using the MQTT Extension.
  • Each site deployment includes an Optix Edge device functioning as the site's local MQTT broker/client.
  • To secure the communication, we need to implement certificate-based security (SSL/TLS).
  • Since our environment is hosted and managed by PTC Cloud, adding custom certificates to the server's Java truststore (jssecacerts located at <Java Install>\jre_<Version>\lib\security) requires submitting support requests to PTC Cloud operations.
Proposed CA Certificate Approach:
To avoid filing a PTC backend certificate request every time a new site or Optix Edge device is added to our system, we are considering establishing a custom Certificate Authority (CA):
  1. Import a single Root/Intermediate CA certificate into the PTC Cloud ThingWorx Java truststore (jssecacerts).
  2. Generate unique broker/device certificates for each individual Optix Edge device and sign them using this trusted CA.
  3. Establish SSL/TLS connection from the Optix Edge device to the ThingWorx MQTT extension.
Key Questions :
  1. CA Trust Chain Validation: If the custom Root/Intermediate CA certificate is added to jssecacerts on PTC Cloud, will the underlying Java runtime and ThingWorx MQTT Extension automatically validate and trust any new Optix Edge device certificate signed by that CA without requiring backend updates for every new device/site?
  2. PTC Cloud Process & Requirements: What is the recommended process for submitting a custom CA certificate to PTC Cloud operations for inclusion in jssecacerts? Are there specific certificate formats (PEM, DER, JKS) or chain requirements?
  3. ThingWorx MQTT Extension Compatibility: Are there any known limitations or specific configuration parameters required in the ThingWorx MQTT Extension/Thing Templates to support CA-signed client/broker certificates?
