8-Gravel
PTC System Monitor for Thingworx
Hi Experts,
Can I configure a PTC System Monitor for monitoring multiple Thingworx instances. My use case requires me to perform system monitoring for multiple instances of Thingworx deployed in different geographical locations. Can this be achieved by deploying a single PSM solution which can configure multiple dynatrace instances (for each TWX server respectively) ?
Any directions will be really helpful.
Ankit
This is not an answer to your question but just FYI before you implement your use case using PSM, march 2021 is end of life for PSM, we will look for its alternative in coming month.
Mukul Narang
8-Gravel
Thanks Mukul,
I am aware this will not be supported beyond March 2021.
Ankit
Hello @AnkitPandya
If the previous response answered your question, please mark it as the Accepted Solution for the benefit of others with the same question.  If you still have issues, please let us know.
Om Dukiya
