Hi Shalini,
You can connect Windchill to ThingWorx using Navigate. Steps are mentioned in ThingWorx Navigate Installation Guide .
Arshad
@svisveswaraiya_285988
Could you please tell your use case here. What exactly you are trying to do. so that we can provide solution according to that.
Mohit
Hi Mohit,
We have a customer who has already using windchill product, now we are developing a custom UI  using ThingWorx.  Since both are from PTC looking for a common way to talk to each other.
Hema
Hi @HemalathaMsk
you can use ThingWorx flow to execute Windchill connector and use few service with ThingWorx. This is the Link
go through this and let us know if it helps.
Mohit
Support
Hi @svisveswaraiya_285745.
If you feel your question has been answered, please mark the appropriate response as the Accepted Solution for the benefit of others with the same question.
--Sharon
