6-Contributor
ptc-windchill-integration-connector ValidateConnection failed
hi there
I think I wrote the configuration correctly, HTTPServer Ping Succeeded too.
But the Validate connection keeps failed.
So I want to check the log. Which log should I check?
I'm a beginner, so please tell me exactly..
I'll wait your reply thx
@YC_9410522 Start by looking at the Integration Runtime log and look for errors. If there is an error and you need more info increase the log level using logback.xml configuration file.
Here is link to the Runtime Service for Integration Connectors guide.
Support
HI @YC_9410522.
If you found the previous response helpful, please mark it as the Accepted Solution for the benefit of others with the same question.
--Sharon
