ptcschartline in twx 9.2
In twx 9.2, iam using ptcschartline. Autoscaling x-axis is not available. When the xaxis datas are less it is not showing complete values. Instead it is coming with dots as i captured in attached image. How to fix this.
Hello @AP_9587236 .
I have checked that autoscaling property is only available in Label Widget. pls check the below linked community post for the reference:
https://community.ptc.com/t5/ThingWorx-Developers/Line-Chart-Y-axis-is-not-autoscaling/m-p/760491#M55503
Regards
Bhawna
