QueryDataTableEntries with TaggedWith does not work
I am trying to filter a DataTable using QueryDataTableEntries for a column that contains tags.
According the the documentation I am using this filter expression (where type of field Context is TAGS and Tag type is Model Tags), but the filter does not seem to have any effect:
let filters = {
	"filters":
 "type": "NotTaggedWith",
 "fieldName": "Context",
 "tags": "PTC:factory-mv"
let result = me.QueryDataTableEntries({
	values: undefined /* INFOTABLE */,
	maxItems: 500 /* NUMBER */,
	tags: undefined /* TAGS */,
	source: undefined /* STRING */,
	query: filters /* QUERY */
I also tried to get all the data, put it into an Infotable and query that one with the same effect.
Can anyone help on this?
22-Sapphire I
I think you are not defining the tag properly for the filter
check out the example in the helpcenter.
http://support.ptc.com/help/thingworx_hc/thingworx_8_hc/en/#page/ThingWorx/Help/Composer/Things/ThingServices/QueryParameterforQueryServices.html
OCMutz12-AmethystAuthor
this is an exerpt from the help center:
"filters": {
 "type": "And",
 "filters": [
 "type": "GT",
 "fieldName": "Duration",
 "value": "12"
 "type": "TaggedWith",
 "fieldName": "tags",
 "tags": "MaintenanceIssues:PowerOutage"
To me it looks quite similar to what I wrote above exept that I do not have an additional and expression.
22-Sapphire I
That's interesting ... I looked at the Help center 8/9 and it has it slightly different, which shows each tag as a JSON pair, maybe try it this way? If this works, then probably need to bug whereever that example came from
var query = {
 "type": "NOTTAGGED",
 "tags": [
 "vocabulary": "Applications",
 "vocabularyTerm": "Testing"
 "vocabulary": "Plants",
 "vocabularyTerm": "Sedona"
