querypropertyhistory does not fetch all the rows between the specified date
querypropertyhistory does not fetch all the rows between the specified date (start date and end date) even though the specific value stream has entries for a specific time period
How are you logging the data? If it is in "value change" mode, did the data change in that period of time?
Cheers,
Vinicius.
asekar5-Regular MemberAuthor
Hi Vinicius,
            Yes.. the data is streaming from kep and I'm sure that data exists for a specific period of time. Data change type is set to value
Arvind
22-Sapphire I
Could it all be MaxItems related? Did you set that?
Hello Chung,
         Thanks for your reply.
I do not think it could be related to max items. When I set this, it does not honor the start date and end date parameters. Total number of rows fetched is equal to max items in this case.
Arvind
22-Sapphire I
Ok so you aren't missing entries just because you are only pulling 500 records but there might be 1000 in the timespan you are requesting.
Could there be a timezone offset? are you requesting data for a location that is in a different time zone compared to your location?
