QueryPropertyHistory returns partially empty rows
I just experienced a problem with QueryPropertyHistory when querying data from a thing (logged with a Value Stream). When I select a time interval I'm interested in the result might have rows where some values are empty (undefined). However, if I expand the time frame (set an earlier startTime) the rows that were partially empty are usually filled in and there are new rows with some empty values.
I have understood that writing data to streams is asynchronous but I'd expect that the writing should be done one event (row) at a time. This can happen even if there are minutes between the query start time and the actual first "row" time.
Example (start date X, end date Y):
value1value2timestamp
19just-example-dont-care
28just-example-dont-care
37just-example-dont-care
4just-example-dont-care
Example (start date X - Z, end date Y):
46just-example-dont-care
5just-example-dont-care
Any ideas? This really messes up my system.
<EDIT>
The same happens if I call the QueryPropertyHistory from a service I created or "manually" from the Thing -> Services -> Generic Services -> QueryPropertyHistory. I've changed only the endDate & startDate (query is empty and maxItems is 500).
Could this be related?
</EDIT>
BR,
Risto
Hi Risto Vaaraniemi​,
Are you viewing the result in a Grid on a Mashup or directly Testing the service in the Thing?
If you are doing it on the Mashup; the thread Re: Issue on QueryPropertyHistory could be related.
Also, please confirm the ThingWorx version you are on?
Please also confirm the Database you are using?
I'm using PostgreSQL through "ThingworxPersistenceProvider".
I've called QueryPropertyHistory in my own service and also through the thing -> Services -> Generic Services -> QueryPropertyHistory (not on any Mashups) with same results. I've changed only the endDate & startDate parameters (query is empty and maxItems is 500). Usually I get about 10 to 20 rows of data.
Version: 7.2.5-b56
-Risto
