Jan 16, 2025 4:15 AM UTC
QueryPropertyHistory throws DataAccessException: [2,006] when start date and end date not specified
I am using ThingWorx Platform Release 9.3.
QueryPropertyHistory does not work when start date and end date not specified, throws DataAccessException: [2,006] Unknown error occurred.
Here are the errors that I faced
Unable to Invoke Service QueryPropertyHistory on TE2-SEAL_PUMP1-M1 : com.thingworx.common.exceptions.DataAccessException: [2,006] Unknown error occurred. Contact the administrator if this re-occurs.
Support
Jan 16, 2025 7:03 AM UTC
Hi @DL_12699107,
Please refer to this similar community post.
Could you please review and share the value stream configuration for entity TE2-SEAL_PUMP1-M1? (is it RemoteValueStream or ValueStream? What persistent provider is configured?)
And please check database.log and Error.log from ThingworxStorage/logs and the logs directly on the database server.
Also, can you please confirm whether QueryPropertyHistory can always be executed successfully if you specify a start date and/or end date?
